В начале работы с программой возникает ошибка!
Сообщение DivS » 13 фев 2007, 20:38
При открытии программы возникает ошибка:
Stream is not a valid.resources file! It was possibly truncated.
Лог ошибки:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Stream is not a valid .resources file! It was possibly truncated. ---> System.IO.EndOfStreamException: Unable to read beyond the end of the stream.
at System.IO.__Error.EndOfFile()
at System.IO.BinaryReader.FillBuffer(Int32 numBytes)
at System.IO.BinaryReader.ReadInt32()
at System.Resources.ResourceReader.ReadResources()
--- End of inner exception stack trace ---
at System.Resources.ResourceReader..ctor(Stream stream, Hashtable table)
at System.Resources.RuntimeResourceSet..ctor(String fileName)
at System.Resources.ResourceManager.CreateResourceSet(String file)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture)
at Xceed.UI.Skins.ImageSkinBuilder.BuildFromResource(ResourceManager resourceManager, String resourceKey, LayerRenderMethod glyphHandling)
at Xceed.UI.WindowsXP.WindowsXPTheme.Init(RowHeaderPaneStates states)
at Xceed.UI.WindowsXP.WindowsXPTheme.get_RowHeaderPane()
at Xceed.UI.WindowsXP.WindowsXPTheme.PaintRowHeaderPane(Graphics graphics, Rectangle rectangle, Color foreColor, Color backColor, Double opacity)
at Xceed.UI.Adaptive.AdaptiveTheme.PaintRowHeaderPane(Graphics graphics, Rectangle rectangle, Color foreColor, Color backColor, Double opacity)
at Xceed.Grid.RowSelectorPane.PaintBackground(GridPaintEventArgs e)
at Xceed.Grid.PaintManager.PaintRowSelectorPane(PaintEventArgs e)
at Xceed.Grid.PaintManager.PaintGrid(PaintEventArgs e)
at Xceed.Grid.GridControl.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
PrintEnvelopePro
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/PrintEnvelopePro.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
log4net
Assembly Version: 1.2.9.0
Win32 Version: 1.2.9.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/log4net.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Xceed.SmartUI
Assembly Version: 3.3.5179.0
Win32 Version: 3.3.5179.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Xceed.SmartUI.DLL
Xceed.Grid
Assembly Version: 2.5.5179.0
Win32 Version: 2.5.5179.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Xceed.Grid.DLL
RIT.ReportLib
Assembly Version: 1.0.2467.24272
Win32 Version: 1.0.2467.24272
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/RIT.ReportLib.DLL
Reports
Assembly Version: 1.0.2550.29407
Win32 Version: 1.0.2550.29407
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Reports.DLL
RIT.Commons
Assembly Version: 1.0.2531.18702
Win32 Version: 1.0.2531.18702
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/RIT.Commons.DLL
Mvp.Xml
Assembly Version: 1.0.1974.21534
Win32 Version: 1.0.1974.21534
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Mvp.Xml.DLL
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Contact.Interface
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Contact.Interface.DLL
Xceed.UI
Assembly Version: 1.0.5179.0
Win32 Version: 1.0.5179.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Xceed.UI.DLL
Contact.NHiber
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Contact.NHiber.DLL
NHibernate
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/NHibernate.DLL
Nullables
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Nullables.DLL
NHibernate.JetDriver
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/NHibernate.JetDriver.DLL
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
Nullables.NHibernate
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Nullables.NHibernate.DLL
Iesi.Collections
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/Iesi.Collections.DLL
RIT.Filters.Core
Assembly Version: 1.0.2547.20763
Win32 Version: 1.0.2547.20763
CodeBase: file:///C:/Program%20Files/RussianIT/ПечатьКонвертов/RIT.Filters.Core.DLL
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///c:/windows/assembly/gac/system.runtime.serialization.formatters.soap/1.0.5000.0__b03f5f7f11d50a3a/system.runtime.serialization.formatters.soap.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Посоветуйте, как исправить?
P.S. Поправьте размер окна ввода текста при создании нового топика форума, а то он всего 3 строки.
DivS
Сообщение vva » 14 фев 2007, 08:32
Поищем отчего может быть такая ошибка.
Чтобы приблизиться к решению, сообщите пожалуйста какая у вас версия операционной системы Windows (случайно не Windows 2003?) и какая установлена тема рабочего стола
и если не затруднит, киньте также лог-файл
("C:\Program Files\RussianIT\ПечатьКонвертов\printenvelopepro.log" )
а ещё лучше прописать в файл конфигурации логов ("C:\Program Files\RussianIT\ПечатьКонвертов\printenvelopepro.exe.config" )
level value="INFO"
в обоих случаях (по умолчанию там прописано level value="ERROR" )
после этого воспроизвести ошибку и прислать нам лог-файл
ok, посмотрим
Сообщение DivS » 14 фев 2007, 09:08
Версия Windows XP Home 5.1.2006 OEM предустановлена ASUS,
Для оформления использую Vista Transformation Pack 6.0
Есть подозрения что он заменил нужные сист. библиотеки.
В силу малого опыта и недооценивания логов при анализе работы ПО я не
допонимаю как реализовать ваше предложение:
"а ещё лучше прописать в файл конфигурации логов ("C:\Program Files\RussianIT\ПечатьКонвертов\printenvelopepro.exe.config" )
level value="INFO""
DivS
Сообщение vva » 14 фев 2007, 09:23
у нас есть версия из-за чего может падать
вечером попробуем протестировать на указанной вами конфигурации и выложить исправленную версию
Сообщение RDF » 14 мар 2007, 17:04
vva писал(а):у нас есть версия из-за чего может падать
Возникает аналогичная ошибка.
Windows 98 SE. Установлены все рекомендуемые на сайте компоненты.
RDF
Сообщение vva » 14 мар 2007, 18:01
значит мы подумали что нам делать с этим классом ошибок и решили что мы не поддердиваем работу с различными Transformator-ами стилей Windows связано это с покупными компонентами интерфейса которые мы используем
опишите, не стоит ли у вас поверх Windows 98 что нибудь вроде описанного
а если не стоит, то какая установлена тема рабочего столе
Сообщение vva » 14 мар 2007, 18:02
и кстати, какая версия Печати конвертов у вас стоит?
последнее обновление (1.0.0.1) более строго отслеживает необходимые компоненты
Сообщение RDF » 15 мар 2007, 10:19
Поверх Widows ничего не стоит.
Рабочий стол без темы. Все минимально.
Версия 1.0.0.1
Собственно ошибка возникает при работе с модулем печати на конверт (PrintEnvelopeEx).
Я его и ставил изначально.
На стадии предварительного просмотра конверта и выскакивает ошибка.
RDF
Сообщение cheery » 15 мар 2007, 16:36
Мы протестировали программу на Windows 98.
Печать конвертов (как и прочие функции) выполняются в данной операционной среде без нареканий.
Возможно дело в вашем принтере или в настройках операционной системы.
cheery
Сообщение cheery » 15 мар 2007, 17:02
Назовите, пожалуйста, какой у вас принтер.
У нас есть данные, что на следующих принтерах возникали проблемы при печати конвертов:
1. Canon 1500 Pixma
2. HP Laser 3015,3380
cheery
